Have a 06 Charger had interior wire burn had to replace wire harness put a 300 dash and all the interior components to go with starts but trunk pop don't work stuck in limp mode won't come out of first interior lights don't work and blower for ac don't turn off some of the dash don't work
Help
You need to use an advanced scantool...not a "code reader"...to check all of your car's modules for DTCs.
If you've gone through all that trouble, then you should invest $75 or so in AlfaOBD and a Bluetooth OBD adapter. Among other things, that will allow you to scan for BCM codes. Also, you'll be able to test individual components easily.
That will tell me everything I need to know on what's wrong with my car and another thing will that me replacing what I did mess up with void any of the recalls that I just found out that I have on my vehicle
