First off i have searched over and over and cant find any posts that solve my problem. Ok first off my car is a 2006 charger r/t. Now i have tried many ways of wiring them (plug and play, plug and play with cancelers, relay harness, relay harness with canceler) and nothing works. The problem is one turns on the other doesn't most of the time. Its like a game of Russian roulette with the headlight switch if both come on. When (rarely) they both come on they do stay on and do NOT flicker.
If you're running them with relay and canceller and your grounds are proper it sounds like your ballasts or bulbs have gone bad. Either they were duds or they were damaged when they were getting improper current. If you can, send them back and get a replacement. Just be sure to check your wiring, polarity and positive/ground contact.
I was running them (with a 35w kit) fine for a month or 2 with no problems then it started doing this and i have tried different kits since then all new and had this problem. Has anyone here tried the cree led headlights?
I have Oracle LED headlights in my fogs and they're amazing. I had a set in my headlights too before I went with a stock HID conversion.
What brand HIDs are you using? There's really only two sources I'd trust to not give me problems. TheRetrofitSource and DiodeDynamics.
Related Threads
Dodge Charger Forum
1.8M posts
46.2K members
Since 2006
