I bought a fiberglass hood and everybody wants to charge me 100+ just to install it. Is it easy to install it myself?
Thanks!
yes just make sure you have someone to help you! u may need to drill out a bigger hole very carefully for the hoses to the spray nozzels
Be careful with it...it is tricky. After you line it up, do not torque the bolts down until you lower the hood (slowly) and check your lines. You will probably have to adjust several times to get it right, then torque it down. Then use the height adjusters up front to get her lined up perfectly.
Reactions: hawkeye4077
Here you go man. This is all you need to know about this.
Here
