Are you happy?
  • Yes
    Votes: 1 50.0%
  • No
    Votes: 1 50.0%
1 - 13 of 13 Posts
Dodge Charger srt will be sitting for a long time. Any advice on what I must do to keep the charger in good condition?
New battery has been put on yesterday.
I must turn it on once a week right?
Fill up the gas tank as well?
What else do you Recommend
Put it on a battery tender . much harder on it to start it unless you can drive it to operating temp. gas stabilizer in the tank. over inflate ( 45-50 PSI) the tires to keep from flat spotting.
Which battery tender can I use on Dodge Charger srt8 2008. The car has no coolant. Is it safe to turn on until it’s at operating temp? All of this is new to me.
The
The dodge is a 19 gallon car. For gas stabilizer i put in 8oz like in this picture?
It sounds like you don't plan on fixing anything now and you don't say how long the car will sit but based on the issues it has I would air up tires and use a battery tender. skip the Stabil since it won't mix anyway and drain or siphon as much fuel out as you can and park it.
Discussion Starter · #11 ·
Can I connect the tender in the trunk?
You sure I shouldn’t top the gas off?
It’s 3/4 full. I ordered a tender and sta bil but il cancel the stabilizer I got the tender that is weatherproof!
1 - 13 of 13 Posts
