hey guys i have the footwell lights from led glow and im not satisfied. maybe its cause its the 7 color ones so they are not as bright as just one color set.im using the cig lighter tap
i want to buy pods or led strips instead. and i also want to put light in the map pockets.here are my questions
1. how do i connect all four pods to one switch? and map pocket lights?
2. how do i use the power for the cig lighter to power all four footwell lights and map pocket lights? can i do it?
3. if i can,does there have to be a fuse?
im pretty sure you guys know what i want to do and many of you have done it:TU:
thanks:D
1. Connect all power wires to one that THEN goes to the one power/switch, connect all grounds together that again goes to your one ground source.
2.See above, yes u can
3. No..LEDs draw very little power and I assume those lights are for when the car is not running. Unlike LED Halos or grille lights which often are turned on when the car is running, in which case an inline fuse is generally recommended.
Check this out for wiring diagrams... http://www.oznium.com/forum/topic20
Hope it helps!
DrBill
Check this out for wiring diagrams... [url]http://www.oznium.com/forum/topic20[/URL]
Hope it helps!
DrBill
Good Post! REPS!!!!!!!!!!!!
Check this out for wiring diagrams... [URL]http://www.oznium.com/forum/topic20[/URL]
Hope it helps!
DrBill
wow dude!:TU:
that was such a great reply..it so simplified everything and the link is awsome, im going with oznium too.im going have them run while i drive cause i love peoples reactions so ill put an inline fuse.where would i put it?
edit: never mind i know where to put the fuse lol
Hope it helps! Let me know if i can help you in any way...
Drbill
Good post Bill! I also did this mod recently and can give you a walk-through. Send me a pm if you have any trouble at all.
