Is there continuous Power inside I can jump off of
901 views 3 replies 3 participants last post by  Punk55
I know I can run a wire from the fuse box (in either direction) but is there a continuous power easily accessible from inside I could tap into?
The cig lighter turns off after power is off, so that isn't an option.
I want to install LED's that I can leave on that are app controlled.
#2 ·
Welcome to Chargerforumz! We are glad to have you here. There is a fuse in your trunk PDM that can be moved (12) from IGN to always on for the cigarette lighter power outlet.
#3 ·
Ahh, ok so, just make the cigarette lighter continuous then piggy back off that? Not a bad idea. I wouldn't mind that lighter permanent anyway to keep charging things left in.
I will try that, thanks. Might still end up running a wire from the trunk, but this is a good answer thanks.
I do a lot of LED work on my cars. Usually I run a wire from the trunk and install a distribution box to run LEDs from.
