Likely the engine oil cooler, they are the usual coolant leak that you are unable to find. If you remove the upper intake and see coolant in the valley where the oil cooler is located then that's the issue. It's a pretty easy fix but unfortunately you don't know until you remove the upper intake and visually see the coolant around the oil cooler.
