Looking To Borrow Or Rent A Differential Case Spreader if anyone has one gathering dust and would like a little return on it.
Thanks,
I used to be able to pry the center out of the differential on my Dana although the hosing was cast iron. I wonder if you really need a spreader or if it can be done without?
Its required to setup the side pre-load. You zero an indicator and spread it to no more than .012". Install a snap-ring that doubles as a shim, then let off on the spreader looking for a retained spread of .007-.009 using different thickness snap rings if needed..
Then adjust lash like this.
123020
Reactions: Nuwanda
