Hey everyone,
I’m trying to solve my bluetooth issue and I’ve replaced the module with the latest version, I’ve updated the software via usb and also tried pulling the fuses. No luck. So I took out the dash bezel and behind the radio I see the usual three connections but then a 4th loose wire but I can’t seem to find a spot for it. I’ve attached a picture. If anyone knows what this is that would be a big help. Thanks!
Did you take it into the dealer to make sure the software was updated to the latest revision for the BT module. -- I know you said you had the latest version, but there was an update for that module to resolve BT connectivity issues.
I have no idea what that plug is for.
I haven’t. I saw a guy on YouTube use the same part number I installed and it was just plug and play for him. I’ll definitely take it to the dealer to check it out because I wasn’t aware of any updates for that module. Thanks!
