New here, been reading quite a few forum posts to help resolve my issue. None exactly helped me.
A few days ago, I was driving and received a Service Shifter alarm. A few moments later, I got service engine, service transmission, service ABS, and service power steering with probably a few more alarms. I was driving 60mph and my cluster said I was currently in P. Out of fear that I was about to have a major failure, I pulled over into a gas station parking lot. After pulling over my shifter was blinking red and I was unable to put my car into park at first.
At this point I shut off the vehicle and was unable to turn it back on again. I got No Bus on my odometer.
The next few hours were spent trying to diagnose the problem. Checking fuses, unhooking certainthings such as my headlights, battery, etc. At the point I didn’t have a scanner on me.
After finally giving in and calling someone for a ride, my car magically started with no alarms on my dash. I hurried and drive my vehicle home. About 10miles away.
The next morning I started my vehicle and went to Walmart and bought a new battery. On the drive home I got service shifter again. Luckily I was around the block from my home.
Since then I have checked the connections to my pcm, replaced the battery, and checked for blown fuses. So far, no luck.
Now I currently have no alarms on my dash but have multiple alarm codes.
Which are:
U0140 - Lost communication with BCM
U1110 - Lost Vehicle Speed Message
U1120 - Lost Wheel Distance Message
U11BC - Lost Brake Switch Message
U0101 - Lost communication with TCM
U0001 - High Speed CAN Communicstion Bus
U1267 - No Valid Data from ESM on CAN
Any help would be greatly appreciated. Currently in a bad spot and do not have any extra cash to pay for a mechanic. This is my daily driver and with my current situation I have had to take a few vacation days. Thank you!
Which are:
