1 - 11 of 11 Posts
Seriously considering lowering springs for a couple reasons
1. The look. Personally I think the Chargers should sit a little lower. To me it looks more aggressive and more aesthetically pleasing.
2. The performance. As a sports car I'd like my Charger to feel a bit tighter especially turning.
I know I can achieve both of these with lowering springs but. . . I've heard that lowering the car can mess up the camber causing uneven tire wear. I've heard that you should let them settle in and then get an alignment but I know that tire wear can still be a problem.
I'm not trying to spend thousands on a cloilover kit. Does anyone know how to successfully install lowering springs without any issues?
Vendor
Lowering springs or coilovers greatly improve the stance of these cars! Both are a fairly straight forward install. We recommend driving the car for a few days afterwards, then getting a alignment. The coilovers would be easier to install, since you don't have to take the front springs apart, and it will be a easier install for the rear. Plus you will get more adjustability. I've attached links to a couple different options.
Eibach Pro-Kit Lowering Springs
KSport Kontrol Coilover Kit
So with the eibach lowering springs installed after a couple days get and alignment and that would solve uneven tire wear issue I've seen?
Does the KSport kit come in an AWD version??? Have H&R's on now w/stock struts and the only options for the struts us AWD owners have are nothing in comparison to whats available to RWD's...but don't want to be spending thousands right now....
^^^ I was wondering the same thing. Very few options out there for our AWD 5.7s.
1 - 11 of 11 Posts
