Mid-muffler delete??
Discussion in 'All Wheel Drive Chargers' started by BigHoss, Apr 12, 2017.
  1. BigHoss
    BigHoss New Member
    Feb 11, 2017
    13
    1
    Gender:
    Male
    Minnesota
    Vehicle:
    Dodge charger
    Vehicle Year:
    6th Gen - 2009
    Trim?:
    R/T
    Thinking of doing a mid-muffler delete on my 09 r/t AWD. Will doing this hurt the engine in anyway? I'm concerned about losing back pressure and hurting the engine and losing my warranty.
  2. Stevens12
    Stevens12 Active Member
    Mar 27, 2012
    2,170
    Media:
    21
    Albums:
    3
    148
    Altoona, Pa
    Vehicle:
    Charger SRT8
    Vehicle Year:
    7th Gen - 2013
    Trim?:
    SRT8
    Color?:
    Billet Metallic
    Nope, won't hurt a thing and when I did it on my 2012 r/t, I noticed no loss of power from it. Remove it and enjoy the new exhaust sound.
    Skidz likes this.
  3. Skidz
    Skidz New Member
    Dec 17, 2015
    62
    Media:
    4
    Albums:
    1
    3
    Central Illinois
    Vehicle:
    Charger
    Vehicle Year:
    7th Gen - 2013
    Trim?:
    R/T
    Color?:
    Pitch Black
    I concur with Steven. Best inexpensive mod I've ever made on a car.
  4. BigHoss
    BigHoss New Member
    Feb 11, 2017
    13
    1
    Gender:
    Male
    Minnesota
    Vehicle:
    Dodge charger
    Vehicle Year:
    6th Gen - 2009
    Trim?:
    R/T
    how bad is the drone??
  5. egoods
    egoods New Member
    Aug 5, 2016
    7
    0
    Gender:
    Male
    Detroit
    Vehicle:
    Charger
    Vehicle Year:
    7th Gen - 2014
    Trim?:
    R/T
    Color?:
    Torred
    At least on my 2014 there is a slight drone at highway speeds when the MDS kicks in, this is due to the gearing in the AWD vehicles, it just so happens to put the RPM right in the sweet spot to drone. I used a tuner to disable MDS (lost about 2-3mpg in fuel economy), when I was researching the issue a while back I stumbled across a few posts that stated you could put it into manual shift mode once at highway speed and it would handle shifting for you... those posts were from a while ago and unfortunately for me that's not the case (downshifts like normal, but it holds the gear when accelerating up to an obnoxious RPM).
    Many people aren't bothered by the drone, and to be fair it's not deafening (I've had to point it out to people riding in my car) but it was getting on my nerves. Otherwise I love the muffler delete, it's the way these cars should've sounded from the factory.
  6. BigHoss
    BigHoss New Member
    Feb 11, 2017
    13
    1
    Gender:
    Male
    Minnesota
    Vehicle:
    Dodge charger
    Vehicle Year:
    6th Gen - 2009
    Trim?:
    R/T
    Egoods thanks for the info.
  7. SolApathy
    SolApathy ... Moderator Site Supporter Level 5
    Oct 10, 2015
    429
    Media:
    28
    Albums:
    1
    112
    Gender:
    Male
    USA
    Vehicle:
    Charger SRT 392
    Vehicle Year:
    7th Gen - 2015
    Trim?:
    SRT8
    Color?:
    B5 Blue
    Deleting the mufflers is not going to cause any drone. Deleting the resonators will increase drone significantly, as their function is to reduce drone.
  8. egoods
    egoods New Member
    Aug 5, 2016
    7
    0
    Gender:
    Male
    Detroit
    Vehicle:
    Charger
    Vehicle Year:
    7th Gen - 2014
    Trim?:
    R/T
    Color?:
    Torred
    I'd be happy to re-enable MDS and record the drone that my car (which has a muffler delete, but retains the resonators) has on my way to lunch today... The 3.06 rear gearing in the AWD Chargers put the RPM right into that sweet spot at about 75-80 with MDS engaged. Your statement is true of the RWD Chargers which have 2.65 rear gearing. Not trying to be argumentative, just want to provide good info, as it's something I wish I was aware of before I removed my mufflers.
    Edit: Also, the purpose of resonators is to alter the resonance frequency of the exhaust to a frequency outside of what the exhaust system is capable of producing. In this case, they're not sufficient in altering the resonance of the exhaust system. You could certainly eliminate the drone by using different length/design resonators or altering other exhaust characteristics. It's akin to a musical instrument, it must be properly tuned to sound right. I will agree that running without resonators would most certainly create an unbearable drone, but simply having them doesn't eliminate the possibility.
  9. egoods
    egoods New Member
    Aug 5, 2016
    7
    0
    Gender:
    Male
    Detroit
    Vehicle:
    Charger
    Vehicle Year:
    7th Gen - 2014
    Trim?:
    R/T
    Color?:
    Torred
    I'm going to reply again, since it occurred to me that I didn't directly address OP's concern very well. You won't do any damage to your engine whatsoever, and if any dealership gives you issues with a warranty claim they're crazy people (it'd be pretty much unheard of). But, yes the muffler delete will reduce exhaust back pressure, which hypothetically could cause a decrease in engine torque. I don't notice any difference, and without a dyno/more info on how restrictive the mufflers are, I can only speculate... but in my experience large displacement naturally aspirated engines tend to have little issue with a reduction in backpressure, and in some cases it even improves performance numbers. Also, you may notice a slight "wobble" in your RPM at idle for a few days after the delete (it's hardly noticeable unless you're watching your rev counter), but the ECU will adjust to it's new "conditions" and smooth out.
Share This Page
