1 - 20 of 21 Posts
Banned
Whats up Z forum, Im planning on upgrading my fuel injectors and im interested in the Mopar Stage 1 SRT4 Fuel Injectors, they are the same ones that come in the SRT8 Vortech Supercharger kit.
Does anybody have the part number for them??
How many lbs/hr are they rated??
How much horsepower can they handle?
Are they too much for my setup?(380+/-RWHP)
Banned
Man always right on Bill. Reps to ya.
Banned
Man I try to go to a Mopar dealer, and the part number search connot find it. I tried on multiple sites also. Im going to have to call them or something.
put a AD as the last 2 letters , these are old numbers If I remeber correctly they are 562cc instead of 572 cc
Bill
Banned
Same thing, no parts found
Hmm apparently my part number's list is behind the times, Call Stu @ intertia motorsports 512 964 7724...but I think he will recommend stage 2 injectors , depending on your future mods ( they can always scale them back even if they are too much ) stage 2 injector part number Mopar Stage II 682cc/+30% injectors
P4510529
here is some more info
Fuel Pressure_______________43.5 PSI____________58PSI
Stage 0 / Stock '03_________456cc/min__________527cc/min
Stage 1 / Stock '04_________499cc/min__________577cc/min
Stage 2 __________________590cc/min__________682cc/min
Stage 3 __________________622cc/min__________719cc/min*
The stock SRT4 injectors for srt4 are basically stage 1 , another possibility is going with 6.1 injectors ..Ill try to find you specs on the 6.1 injectors ..dont have that info in front of me
Bill
Banned
Discussion Starter #9
Do you think the Stage 2 will be too much?
Think ill gain any HP with the upgraded injectors?
Tuthfuly with the mods you listed in your signature we use 6.1 injectors w/tune scaled for the mods. Stage 2 and above we have installed are usually with for strokers or blown applications
Bill
Banned
Discussion Starter #11
I think I am just going to get the SRT8 injectors.
Think ill see any power increase?
9 Second Club
I think the SRT4s would be a waist of money..... usually reserved for mild forced induction cars or Strokers.....
6.1L should be fine but you should ask your tuner that question. He can tell you the current injectors capacity is with your current setup....... If you were starving for fuel, Im sure you would of had issues by now.......
Banned
Discussion Starter #13
So you guys think I would benifit getting the 6.1 injectors? You guys think i would see a hp increase?
9 Second Club
You will not see any improvement from an injector swap if you are not using your current injectors close to capacity.......
I assume your car was dyno'd with your stock injectors ? Did the tuner comment to you on how much the current injectors were running ?
Banned
Discussion Starter #15
No, he didnt tell me how much Duty cycle they were running.
Johan asked if I had stock injectors though. I dont know for what reason though.
About how much RWHP untill I should swap mine out?
I wont do it unless a see a RWHP gain.
Banned
Discussion Starter #16
I think im running them pretty close to full capacity?
9 Second Club
Thats something I would ask Johan...... in the past he usually has send to me when I need them....
Banned
Discussion Starter #18
Alright thanks. I will ask him.
Banned
Discussion Starter #20
He said I wouldnt need them unless I physicaly need them.
1 - 20 of 21 Posts
