Glass removal:
Push mirror glass case into the full down position
Disconnect and isolate the negative battery cable.
Place your thumbs behind the mirror glass case and push out from the mirror assembly. This will disengage the mirror glass case's snap attachment.
If equipped, disconnect the blind spot indicator and heater wires by pulling on the thumb tabs.
Disconnect the mirror motor glass electrical connector
Remove the mirror glass case from the glass motor by pulling up and out. This will disengage the “hook” attachment at the bottom of the mirror glass case assembly.
Glass installation:
Install the glass case to the motor by pushing the glass case “hooks” into place.
If equipped, connect the blind spot indicator and heater wires
Connect the mirror motor glass electrical connector (Make sure the wires are not caught between the glass case and the motor.)
Push the glass case (3) on until the glass case snaps are fully seated on motor. (An audible snap is normal)
Connect the negative battery cable.
