What is everyone here running for rim offset, i contact vorsteiner about a set of rims, i told them the sizes
20x9.5 front (275 20r40)
20x10.5 rear (305 20r35)
I looked on factory reproductions with those specs they recommended
+12 on front et
+22 rear
Should I follow does guidelines or talk to vorsteiner thanks
Check Tire Rack's numbers for sure. They will have all the wheel sizes, along with the allowable offsets. Offhand, I remember then showing 15MM front, and 25MM rear; a 10MM differential. Since the 12 and 22 fit that, I wouldn't worry a bit then.
