1 - 8 of 8 Posts
So I don’t know if anyone has ever encountered this, but I have tried everything and am stumped! I just bought Spyder headlights that were extremely easy plug and play! The problem is, is I took the turn signal piece from the factory headlight and moved it to my new headlight with no problem, almost. The issue I am now running into, is the turn signals do not work! But they light up with my low beams!! I tried putting them back into the old headlight setup and using them and they still did not work! Somebody please advise!
2017 Dodge Charger R/T
2017 Charger R/T Blacktop
Welcome from AZ.
I'd say that you may have run the wire to the wrong spot. Double check where you ran them
1 - 8 of 8 Posts
