1 - 14 of 14 Posts
im looking to purchase new wheels for my 2013 charger rt. Currently I have 245/45/20 tires on it, and not sure the specs of the current wheels, I was told stock chargers are safe from +15-+25mm for the offset, but also told by another that you’re safe up to +45, I’m worried about interfering with fender, or backspacing, and want to know what mm will I be safe at. Currently looking at anything from 15-25mm
Thanks all!
I'm pretty sure the +45mm is closer to the back-spacing of the all-wheel-drive models, which have a different requirement than the rear-wheel-drive models. My 20"x9" aftermarket wheels are +20mm, same as I used on my 2013, 2017, and now my 2019 Chargers, all rear drive. No issues whatsoever.
Your backspacing, width, and other info on the current wheels can be found on the back by removing a wheel. Factory 20"wheels are pretty close to +25mm. If they're aftermarket, it could be different. I'd start by pulling a wheel to confirm what your current specs are.
Thank you, I’m looking at hellcat replicas, they have +20 mm offset with 5.79 backspacing, and it’s a 20x9 I was told they should fit my 245/45/20s but will probably remove a tire this weekend to confirm.
Those will work and look great with the specs you stated. Post some pics after you get them.
Discussion Starter · #6 ·
Discount tire is saying they don’t fit my vehicle so I’m calling today, to get some more info before buying, see what they’re talking about.
Here's my previous 2 Chargers, a 2013 RT and a 2017 Rallye, plus my current 2019 RT, all with 20"x9" wheels. All 3 sets are +20mm backspace. All 3 have 245-45-20 tires on them. The only difference from these and the ones you mention is the style. Your car IS RWD and NOT AWD, right?
Two sets of these were purchased from Discount Tire Direct. Call them at 1-800-707-8473 and ask for Danny at extension 51854. I've dealt with him for the last 10 years.
Discussion Starter · #8 ·
Here's my previous 2 Chargers, a 2013 RT and a 2017 Rallye, plus my current 2019 RT, all with 20"x9" wheels. All 3 sets are +20mm backspace. All 3 have 245-45-20 tires on them. The only difference from these and the ones you mention is the style. Your car IS RWD and NOT AWD, right? View attachment 92118 View attachment 92120 Two sets of these were purchased from Discount Tire Direct. Call them at 1-800-707-8473 and ask for Danny at extension 51854. I've dealt with him for the last 10 years.
Correct it’s a RWD, I called them and they said it’ll fit they aren’t sure why the website was giving me a different answer, so I’ll go ahead and order mine, on backorder for a couple weeks, but should look nice and clean once they’re here!
They look great, Congrats!
1 - 14 of 14 Posts
