1 - 9 of 9 Posts
Hey guys newbie here.
2013 Charger SXT
Here name is Ruby and I love her.
I am having some issues with the "Auto Park Disabled" wheel speed sensor/ABS/Traction control which I think is just the sensor needs cleaning.
My other issue is the instrument cluster is stuck. After I put air in the tires it got stuck on the "change to Vehicle Speed" mode and none of the Steering wheel buttons (on the top, the bottom ones for the stereo are working fine) are not working at all, So no cruise control etc. Is there a way to reset this?
I am also having a tough time finding a local reputable mechanic that I can trust with my Ruby.
Any help would be appreciated to the max!
Debra
Discussion Starter · #2 ·
Oh wow now at lunch the Cruise Control works but not the left side buttons "Change to Vehicle speed" is still stuck, I swear I have pushed that button 20 times.
I tried doing the Oil Change reset of turning to the Run Position and then pressing the gas 3 times and then turning it off again and....nothing changed.
I am int he St. Petersburg /Tampa Bay area.
2017 Charger R/T Blacktop
Welcome from AZ, have you tried a 15 minute battery disconnect?
Dodgeguy,
Thank you so much for the reply.
I have not, will that bring it back to factory settings?
More than likely needs an ABS sensor. Good news is that it's an easy diagnosis with a decent scantool, cheap part, and simple install.
Welcome from Pittsburgh! The tips above are great places to start. I hope they work for your Ruby!
Discussion Starter · #9 ·
Thank you so much guys for the warm welcome and suggestions.
Now I have to find some place to take it in to get the sensor checked.
Not a dealer!
TC
Debra
1 - 9 of 9 Posts
