1 - 8 of 8 Posts
i just bought a 2007 Dodge Charger and there is no cabin air filter and no slot to put one in? Is this just me?
2017 Dodge Charger R/T
Well you can take it on yourself, I had this saved as a favorite on my computer from another forum to do on my 08, but never got around to it. May still do it when my son takes the car
  1. Installing a cabin fresh air assembly
    This is for most of us that didn't get to add this when we bought our cars new. Here is the complete assembly i got through Mopar Super Center:
    I only used the part that actually holds the filter:
    Here is the part #:
    Tools used for the install: 1/4" & 3/8" ratchets w/short extension,10mm,13mm,15mm sockets, assorted standard screwdrivers,blue painters tape & utility knife(optional)
    So lets get started.
    First remove the 2 pins that cover the ECM located on passenger side of engine compartment.
    Next remove foam piece just under hood strut:
    Next remove the push pins that hold down the long plastic cowl:
  2. Continued....
    Also remove smaller push pins holding the rubber ends on cowl:
    Then with a utility knife or small screwdriver pop off the cover to the nut that holds the wiper arm. Use a 15mm socket to remove the nut:
    Now before you remove the wiper arm use some of that blue painters tape for reference marks when you re-install the wiper arm (Do this on both sides):
    Now you can pull on cowl and set aside. It's only held in by a few clips that snap in:
  3. Now with a ratchet and 13mm socket to loosen both bolts that hold the ECM & support
    With that out of the way. Use a 1/4"ratchet w/10mm socket and remove the 2 nuts holding the cabin air assembly:
  1. Once the bolts are removed remove the ECM out of the way so you have more room to work with when pulling out the old piece and installing the new:
    Now its gonna take a little effort to remove the old piece:
    Now its time to install the cabin air filter holder - Make sure the lower tab slides in for a good seal.
  2. We are almost finish!
    Now make sure the new assembly slides flush against the firewall then adjust the assembly so it goes over the threaded bolts:
    Re-attatch everything in the reverse order and your done:
The new ones take about 30 seconds to change. Big difference obviously haha.
Reactions: TM C-dray
Yeah, wasn't standard on all of them and there seemed to be no rhyme or reason. My 05 Magnum R/T came with one, my 06 Charger R/T didn't (so added it).
Discussion Starter #8
Thank you this helped so much, I bought the car and the air vents smelt like ass and when I went to change the cabin air filter I couldn’t find it, stupid design but I love the car so it’s all good
1 - 8 of 8 Posts
