Centered. Front dash speakers work, just not the door speakersHow is the fade adjusted?
Eq is flat in the middleTIs the equalizer set for them? Mine are for bass so if I adjust them too high, I won't hear much either.
no work done in doors or dashMight have to pull the door panels to check the wiring. Were the front doors worked on?
Was any under dash work done?
