1 - 8 of 8 Posts
Does anyone else experience this issue. sometimes when i am driving without the radio on, i hear a digital beep inside the car. at first i thought it was like a low battery beep on a device that was forgotten but no such device. it comes and goes and definately is digital sounds. once it even sounded like a phone dial tones but its very feint.
Could be the remnants of an aftermarket device that was installed by a previous owner.
The only beep I can think of that caught me off guard once was when the satellite radio was telling me a song/artist I liked was playing.
Are you wearing your seatbelt? That beep drives me bonkers.
There was a hack to disable the chime from repeating ... it will chime once and quit. I used it on my Charger but I don't know if it still works on the latest models. Give it a try. If it doesn't work then you can still disable it with a Tazer. https://www.zautomotive.com/product/tazer/
To disable the seat belt reminder chime:
1. With the ignition switch in any position except On or Start, buckle the driver side front seat belt.
2. Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds).
3. Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.
4. Turn the ignition switch to any position except On or Start to toggle the belt-minder feature from its current setting (from active to inactive, or from inactive to active).
A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed.
(This does NOT disable the INITIAL chime, only the nagging repeats every few seconds.)
Hi nisstyre,
We certainly understand why this may be frustrating. Have you considered having your dealer address this? If so, our team would be happy to get you connected with a Case Specialist to assist!
Alex
Dodge Cares
1 - 8 of 8 Posts
