i was looking to get green oracle flex stips. i was goin to put them on the charger logo on my trunk and also on my grill i was just woundering if they are easy to install
Yeah they are easy to install. You are gonna be hooked as soon as you install them.
depending on where you want to connect them, for the grill you will have to run wires for power, ground, and a switch to the inside of your car.
As for the trunk, just splice into the existing trunk light wires, but they are grouded, which basically means they only go on when the trunk is open, so when you splice into them, to avoid getting a short, cut the negative(purple and green wire) first, connect the negative from the light strip, seal the connection, then do the same to the positive strip. If you need help just send a pm my way
