Hello all.
I have tired everything to fix P2173 Flashing Red Lighting Bolt. I changed the EGR gasket as well as the EGR Valve. I have cleaned the throttle body and the Intake. Checked all the gaskets.
The car runs fine while driving, but sometimes cruising down the highway it will go into limp mode and flash the red lighting bolt. Pull over, restart the car and good to go. At a red light it will do it, sitting there idling normal, then it stalls or just about stalls, shake shudder then idle up to limp mode 1200rmps with the flashing red lighting bolt.
I googled the crap outta this with no luck fixing it. Anyone had the same symptoms or something like this?
