Newbie question here but wasn't having luck in the search. I'm looking to convert at least one of the cig lighter power points to be on with the ignition off. Currently the only was to charge is with ignition on or engine running.
I think there was something with moving the cig adapter fuse on the fuse block in the trunk to the other slot next to the cig port fuse if i remember correctly, that would cause it to be constant instead of switched. You may have to research online, or it may be in your owners book, but i saw that somewhere once. Hope that helps.
