I just picked up a 2 channel dash cam and it came with both the power port plug and a hard wire harness. I know the fuses boxes are in the trunk and under hood but is there an under dash power point for consumer use? The harness has some length but not enough to go to the fuse boxes. I need both switched and constant 12v and ground obviously. Was hoping to run the power to under dash.
i haven’t looked yet to see how to remove the lower dash but figured I would check here first before I go rooting around.
Thanks all!
Wish I could help. I bought a Rove R2-4K dash cam months ago and still haven't gotten around to installing it. Reading instructions is my Kryptonite. Lol
Yeah I have that issue sometimes as well. ;)
I did find this tho.... Pinout for the infotainment Center harness.
These cameras don't pull enough juice to screw up the head unit ....do they?
Dodge Charger (2015-2017) RJ4/VP4 UConnect Head Unit pinout
In looking at this, I can only assume that ...
Pin1 - Constant 12v +
Pin2 - Switched 12v +
Pin 11 Constant -
Pin 12 Switched -
And Pin 43 is common ground
I was thinking of tapping into pins 1 & 2 for 12v power then using the common ground.
Or am I reading this wrong?
