Actually I was wrong, found the info for ya as far as torque goes, but still doesn't directly answer your hp question.
The Mercedes-Benz 5G-TRONIC (also called 722.6) is an electronically shifted 5-speed overdrive automatic transmission. It is in the process of being replaced by the Mercedes Benz 7G-Tronic Transmission which was introduced in 2003. However, all V12-powered cars such as the S600 and S65 AMG still retain the 5G-Tronic, which has a torque capacity of 796 lb-ft, as the newer 7G-Tronic is limited to 542 lb-ft, not enough to handle the torque from the V12 engine.[1] Also, while rear-wheel drive W211 E-Class cars have adapted the 7G-Tronic, those with 4MATIC retain the five-speed automatic, although the current generation W212 E-Class released for the 2010 model year has dropped the 5G-Tronic entirely, except for four-cylinder models.
In Chrysler applications this transmission is identified as the New Automatic Gearbox- Generation One, or NAG1.
