1 - 14 of 14 Posts
Vendor
R1 Concepts- Carbon Alloy GEOMET Rotors!
Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability.
Each rotor is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining require in or to properly balance the finished rotor during the mill-balancing process.
Fine Turned
Next, the castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practive, we regularly achieve .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
After all of the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free.
Geomet Finish
Engineered for only the best performance and durability, these rotors boasts a long lasting corrosion protection though the Geomet finish. This finish also reduces installation time.
BRAKE KITS
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS
FT/RR R1 OPTIMUM BRAKE PADS
FT/RR BRAKE HARDWARE KIT
TOTAL: $250 SHIPPED (V6)
TOTAL: $270SHIPPED (R/T & SXT W/ PERF BRAKES)
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS
TOTAL: $265 SHIPPED (V6)
TOTAL: $285 SHIPPED (R/T & SXT W/ PERF BRAKES)
ROTORS
TOTAL: $185 SHIPPED (V6)
TOTAL: $205 SHIPPED (R/T & SXT W/ PERF BRAKES)
TOTAL: $385 SHIPPED (SRT8)
TOTAL: $205 SHIPPED (V6)
TOTAL: $225 SHIPPED (R/T & SXT W/ PERF BRAKES)
Vendor
Do you have the dual slot fronts for the 6-piston calipers?
Unfortunately we're currently out of stock on those 2-piece rotors for the 6 piston brembos at the moment. We'll be restocking at the end of the month or first week or two of Oct.
Lots of rotor info here, but what about the pads? What are the R1 Optimum pads made of? Also how much to paint the rotors?
Reactions: POWERMAN
Vendor
Discussion Starter #12
The Optimum pads are formulated to be closest to the OEM brake pads which are a ceramic compound. We don't offer the option to paint rotors.
1 - 14 of 14 Posts
