I removed the radio bezel, but how do I remove the temp wiring? It has a red slide clip but it will not move and I cannot get it to come off. How do I removed it?
You should be able to slide the clip back and pull male/female plug apart.
H-D 883 IRON
Try pushing on the clip with a small screwdriver. Takes a little effort but it will come apart.
There is a tab underneath the clip that u must push as you pull out...
DrBill
Just pull it, it will come out
Mine was a little tricky the first time too. But as Ed mentioned, use a small screwdriver to push back the tab and you should be able to pull it apart.
