Can you install a rear bumper with park assist sensors and make them work if you car didn’t originally come with sensors? Is there a harness for it? A plug?
Cables, harness, module, and you will have to find a dealer that will update the BCM (Body Control Module)to recognize the module is installed.
It depends on the dealer. I am confident that it could be around 800-1200 if you have them do all the work. Keep in mind this is an estimate.
The sensors and wire harness come with bumper. I’d have to run wires up to the BCM under hood? Or buy a separate module then plug that into the BCM?
