Okay, I did it.. I bite the bullet and got myself the new 2011+ Spyder Headlights with LED DRL tubes.. I also bought a pair of HID 8000k Low and High beams. About a month ago I was searching the forums relentlessly trying to find answers about how the light output was and the quality of the housing itself.. I didn't have much luck.. If you're in the same boat I was, fear no more.. for I have created a full in depth review.. WITH PICTURES! :TU:
INSTALL:
Wiring aside, replacing the stock headlights with the spyders isn't to hard.. HOWEVER, you do have to take the bumper off.. This seems intimidating but If you can turn a ratchet you can do this.. Simply do what this dude tells you in this video: Spyder Auto Installation: 2011-13 Dodge Charger Light Tube Projector Headlights - YouTube If you're NOT installing HIDs and are just using halogen bulbs this is simply plug and play.. However you will have to switch out your bulbs. BUT.. and this is a big but, I would recommend NOT using halogen bulbs with these headlights as the low beams are projectors.. Your light output is gonna suck. Here's what I found out very quickly when installing HIDs.. Chargers HATE HIDs.. You will need both Resistors and Relays if you don't want your lights to flicker and randomly shut off. The wiring of the HIDs was definitely the hardest part.. If requested I can go more in depth with pictures and info of the install but honestly just save the hassle and take it to a shop. :4-dontknow:
REVIEW:
To clarify, I bought the 2011-2013 Spyder Headlights w/ DRL.. This is the NON HID model.. Which means it is for the Charger models that didn't come with factory stock HIDs.
As for quality of the housing itself I think they look fantastic.. Spyder upped their game to say the least. I was a little worried that because they're made in Taiwan they might look cheap or "plasticy" this is not the case.. They're very 'high-end' looking. These lights change the entire look of the front end.. I was worried these lights would take away the Muscle look and in a way they kind of did.. Don't get me wrong they look MEAN but compared to the stock lights I think the Spyders take it more into the Sport category IMO. They however, do not look ricey. Whatever the case may be.. They look great.
I live out in the middle of nowhere and tested these lights on unlit highways in the bush as well as cities. The low beam projectors actually produce a pretty nice cut off line and do not blind oncoming traffic.. I have not once been flashed. I'm using 8000k HIDs and found that these projectors dampen the light output a little bit.. If you live in the city you'll be fine but if you do a lot of night time highway driving I would recommend not going any lower than 10000k. Adjust the aim of the headlights down if need be. For the High beams get the brightest you can get your hands on.. nobody will be seeing them anyway. I have 8000k in mine and because it's a reflective housing it turns the highway into day time.. it's pretty fantastic. The LED DRL tube (Day time Running Lights) are probably the coolest feature and complete the look of the headlights. They're pure white but aren't obnoxiously bright, they stick out nicely.
Feel free to ask any questions, I will try to help best that I can.. If you would like to see a video of the lights at night let me know and I will upload it onto here..
ENJOY THE PICTURES:
INSTALL:
REVIEW:
ENJOY THE PICTURES:
