101 - 120 of 142 Posts
Garmin 2018.30 (North America) Map update is now available.
After copying the files from your Nuvi device to a USB stick ... the folder/file structure on the USB stick should look like this:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 05YB6S5C.SRX
. │ 05YB6S5D.ASR
. │ 05YB6S5E.ASR
. │ 05YB6S5F.ASR
. ├───JCV
. │ D3191240A.JCV
Performed the Garmin 2018.30 (North America) Map update this week. The "Installation completed successfully" screen has a "OK" button but it didn't do anything. As soon as unplugged the USB drive the Uconnect rebooted and the Garmin Nav worked fine.
I checked the Settings Info menu and it showed the 2018.30 (North America) Map is installed.
Reactions: GMAC
Garmin 2019.10 (North America) Map update is now available.
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. |─ASR
. │ 05ZZYJNK.SRX
. │ 05ZZYJNL.ASR
. │ 05ZZYJNM.ASR
. │ 05ZZYJNN.ASR
. |───JCV
. │ D3191250A.JCV
Moderator
It seems like something is off on this one. After updating my 3490LMT, none of the .ASR files match the above and the .JCV file on my unit is D3191250B.JCV.
I have (4) ASR files, 0607E77L, 0607E77M, O607E77N, and 0607E770
The .SRX file is diffenent too. Mine is 0607E77K
I guess I'll give those a try and see what happens.
Sorry for the confusion. I copied the folder/file structure over from another Dodge Charger forum. Apparently Garmin released a revised 2019.10 and depending on when you updated your device you got different files. The posting from the other Dodge Charger forum was apparently the earlier version. I updated my Garmin device last night and got the same files as GMAC.
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. |─ASR
. │ 0607E77K.SRX
. │ 0607E77L.ASR
. │ 0607E77M.ASR
. │ 0607E77N.ASR
. |───JCV
. │ D3191250B.JCV
There's always three different JCV files for each Garmin North America map release (small medium and large). The three JCV files for the Garmin 2019.10 (North America) Map update are:
D3153260B.jcv (25.3 MB)
D3191250B.jcv (487 MB)
D3060260B.jcv (830 MB)
Which JCV file is installed on your Garmin device depends on the model. If your device has the large JCV file you can load it to the USB for the Uconnect map update.
Map Update on Uconnect CTP11 & CTP12 (2011 - 2012)
Garmin 2019.11 (North America) Map update is now available.
Garmin had two releases for 2019.10 NA ... 2019.10A and 2019.10B
Apparently there were some issues with 2019.10A so Garmin released 2019.10B
This caused confusion with users as to which version of 2019.10 was installed on their devices. So Garmin released 2019.11
I guess Garmin figured 2019.11 will get everyone from 2019.10 on the same maps ... regardless of whether they were on 2019.10A or 2019.10B
If you had 2019.10A the filenames change with 2019.11
If you had 2019.10B the filenames remain the same with 2019.11
Folder/file structure and filenames on the USB stick, for 2019.11, should look like this:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 0607E77K.SRX
. │ 0607E77L.ASR
. │ 0607E77M.ASR
. │ 0607E77N.ASR
. ├───JCV
. │ D3191250B.JCV
There's always three different JCV files for each Garmin North America map release (small, medium and large). The three JCV files for the Garmin 2019.10B and 2019.11 (North America) Map updates are:
Which JCV file is installed on your Garmin device depends on the model. The most common is the medium sized file and that's why D3191250B.jcv is listed in the Garmin 2019.11 (North America) Map update. However, if your device has the large JCV file (D3060260B.jcv) you can load it to the USB for the Uconnect map update .
Garmin 2019.20 (North America) Map update is now available.
The gmapprom.img, ASR and JCV files have been updated in the 2019.20 map update.
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 061IJJSW.SRX
. │ 061IJJSX.ASR
. │ 061IJJSY.ASR
. │ 061IJJSZ.ASR
. ├───JCV
. │ D3191260A.JCV
The update process is described on page-1.
https://www.chargerforumz.com/threads/revised-ctp11-ctp12-map-update-process-2011-2012.165282/
Reactions: GMAC
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 061IJJSW.SRX
. │ 061IJJSX.ASR
. │ 061IJJSY.ASR
. │ 061IJJSZ.ASR
. ├───JCV
. │ D3191260A.JCV
I have a 2014 Jeep Compass Limited with the Head unit RHB17. Garmin is updated and I downloaded the newest 2019.20 maps to my Nuvi40LM. I do not have ANY ASR files in the Garmin unit. I tried it with everything else being the same and my car told me that the map update was "Not compatible" with the unit even though it read the map as the 2019 lower 49 map.
My JVC file is also named "D3479250A.jcv"
Any suggestions?
Only thing I can suggest is to get a Nuvi device that has the ASR file (speech recognition). A Garmin device that supports voice command should have the ASR and SRX files. The four files listed above in the 2019.20 ASR folder is about 824MB.
I grabbed another Nuvi and got all the files. I popped in the USB and it says "Map update was unsuccessful please contact dealer (or something )" then it restarted the Garmin program and said "PND installed successfully." No updates to the maps were actually made This all took around 3 mins.
Reactions: SimplyPallets
SimplyPallets,
If you're updating a 2014 Uconnect unit you need to follow the instructions for the CTP2013 (2013-2014 ) process. The process is different than for CTP11/CTP12 units and there are some additional Garmin files as well.
https://www.chargerforumz.com/threads/revised-ctp2013-map-update-process-2013-2014.165278/page-6
I tried this method and got a different error but a promising one. My RHB unit is running on software version 44.00.01 and I have downloaded the 55.00.01 version, however, cannot seem to have it see those files when plugged in (either USB port on the head unit or the USB port in the glovebox). Can anyone link to the procedure to update to 55.00.01? I can't seem to find it. Thank you in advance.
