121 - 140 of 142 Posts
Garmin 2019.30 (North America) Map update is now available
Folder/file structure on the USB stick should look like this:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 062Y6EIO.SRX
. │ 062Y6EIP.ASR
. │ 062Y6EIQ.ASR
. │ 062Y6EIR.ASR
. ├───JCV
. │ D3191270A.JCV
If you have access to the large JCV file it will be named "D3060280A.JCV"
The update process is described on page-1.
https://www.chargerforumz.com/threads/revised-ctp11-ctp12-map-update-process-2011-2012.165282/
I did the update overnight last night. It worked like a charm!! Its so nice to have updated maps again!!
Garmin 2020.10 (North America) Map update is now available
Uconnect CTP11 & CTP12 (2011 - 2012)
Full Coverage North America 2020.10 map
When you are finished, the folder/file structure on the USB stick should look like this:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 065C1IBK.srx
. │ 065C1IBL.asr
. │ 065C1IBM.asr
. │ 065C1IBN.asr
. ├───JCV
. │ D3191280A.jcv
Reactions: smaz1087
I just had quite an adventure with this that I thought I'd share.
I bought a 3490LM with a broken screen off of ebay, plugged it in, fully updated it, then turned it on to find out that only half of the screen would respond to touch. Because of this, no matter which way I turned the screen I was unable to get into the diagnostic menu to put the device into MTP mode. Despite this, I was still able to update the maps on my 2013 Dart with a 2012.5 8.4 Uconnect to 2020.10.
What I did was click "Map Options" in Garmin Express, then select "Install to Computer". I'm not even sure this is necessary, but I did it. After this was done, I waited a while for Windows to index the files so I could search them.
I was able to find all of the files needed except for gmapbmap.img and gmaptz.img in "c:\programdata\garmin\CoreService\Downloads", so I left those out and it worked fine.
The only issue with this is that I need to wait for someone to post the correct files next time an update is released so I can search them instead of taking them from my garmin, but I can deal with that.
My USB stick for 2020.10.
└───Garmin
. │ gmapprom.img
. ├───ASR
. │ 065C1IBK.srx
. │ 065C1IBL.asr
. │ 065C1IBM.asr
. │ 065C1IBN.asr
. ├───JCV
. │ D3191280A.jcv
Thanks everyone!
2020.20 North America full coverage map is available for download from Garmin Express
The updated 2020.20 file names are as follows:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 068UPERK.SRX
. │ 068UPERL.ASR
. │ 068UPERM.ASR
. │ 068UPERN.ASR
. ├───JCV
. │ D3191290A.JCV
NOTE: The LARGE *.JCV filename is D3060300A.JCV
Moderator
It's not working for me. Apparently, my anti-virus deleted jetmouse and now I can't find it anywhere. The link above wants me to download "'Multy app", which seems very suspicious to me.
I signed up at Navitotal.com and activated my "membership", but I still can't download anything.
The link didn't ask me to install any app when I downloaded the zip file. This was about three years ago so maybe the host site has changed it's processes. I had to disable my anti-virus software to download the zip file. I uncompressed the zip to extract the exec file. I then placed the exec file in a different directory and enabled my anti-virus software. I performed a system scan and the anti-virus software deleted the zip file but didn't flag the exec file.
The zip file packaging must have been a requirement for the host site because the exec file is only 573KB and the zip file is 452KB. Not a lot of compression (~ 20%) but this forum doesn't allow exec file uploads either ... but it does allow zip files.
I compressed the exec file using 7-zip. See if you can download and extract it.
Reactions: GMAC
Your anti-virus software probably will not flag the exec file but your Malware detection software may flag it as Genkey malware. I use Malwarebytes and it flagged the file as Genkey. It's not really a malware file that will affect your computer but it is an exec file used for generating registration keys. Malwarebytes assumes Genkey files are illegal hacker files and flags them. Just add the exec file to the exclusions list and Malwarebytes will ignore it.
Reactions: GMAC
Installed the 2020.20 North America full coverage map today and it installed without any problems.
This is a relief because the 2020.10 map did not install correctly. Luckily the 2020.10 fail did not affect the 2019.30 map I had installed .. so NAV still worked.
I'm not sure what the problem was with 2020.10. So I deleted all the 2020.10 files from the USB device. Then transferred the 2020.20 files to the same USB device ... and the Uconnect map update worked just fine.
Reactions: GMAC
Garmin 2020.30 (North America) Map update is now available.
The 2020.30 folders/directories and filenames for a CTP11/CTP12 Unit should be as follows:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 06CPIQRK.srx
. │ 06CPIQRL.asr
. │ 06CPIQRM.asr
. │ 06CPIQRN.asr
. ├───JCV
. │ D3191300A.jcv
Garmin 2021.10 (North America) Map update is now available.
The 2021.10 folders/directories and filenames for a CTP11/CTP12 Unit should be as follows:
└───Garmin
. │ gmapprom.img
. │ gmaptz.img
. │ gmapbmap.img
. ├───ASR
. │ 06FL4OOW.srx
. │ 06FL4OOX.asr
. │ 06FL4OOY.asr
. │ 06FL4OOZ.asr
. ├───JCV
. │ D3191320A.jcv
My CTP16 uconnect lost the compass and i cannot get to the nav menu , it is frozen in loading maps , do you know how to reflash it or any other option, thanks
