1 - 8 of 8 Posts
Had anyone had their check engine light on for small Evap Leak? I've been told it's usually the gas cap not on right but there is no gas cap. What is causing this?
yeah I've wondered about that newfangled capless filler...might be the problem...there is also a solenoid purge valve somewhere that might throw a code.. P0442 meebee ?
I drive an 06 charger rt, had the same problem even after changing rings on the gas cap. Ended up changing the egr valve to a stock mopar one and haven’t seen the code since??
The easiest solenoid is on the engine, replacing it takes a minute, and its half the price of getting your car scanned so it's a good gamble. The other solenoid is by the filler neck,but again is cheaper than the scan at the dealer. Theres also been a few software updates to resolve this but the under hood valves go all the time.
1 - 8 of 8 Posts
