Mercy. If you were local to me I would show you.
If you do get help try Rock-auto for the plugs. Get the same that came in the car. Don't try to be smarter then the MOPAR engineers.
Below are the tools I use.
Screwdriver for the coil pack wire connectors.
Two short 3/8" drive extensions because of clearance issues and to help spin them out by hand.
1/4" drive ratchet and 10mm socket fore coil pack removal.
Long handle 3/8" drive ratchet to break existing ones loose easier. A regular length handle will work.
I did mine the 2nd time in an hour.
Good Luck.
