Found an absolutely killer deal for a 2012 Charger srt8 The was in a wreck. The guy only had liability, and doesn’t have the money to fix the front end. Engine and transmission are fine, and so is basically everything else but the dash since the airbags went off. I currently own a 2011 Charger SE. I’m planning on buying the entire parts car if I’m able to. What all would I need to swap into my car?
List of things I know I’d need to swap over:
Engine
Transmission
ECU
BCM
Engine and Dash wiring harnesses
Dash (due to blown airbag)
Exhaust
Rear Diff, axles, and wheel hubs
If the suspension parts are working you might want to do that too (shocks, springs, strut brace, roll bars, etc.). Also, steering components are probably different too. For performance purposes and because the new engine will be a lot heavier you will want the new suspension. Look forward to seeing some pics, that's a lot of work!
Reactions: JJsecor27
