I have a 2019 Charger GT. It has the option for the rear sub but it didn't come with one. Does anyone know if it comes pre-wired or will i have to wire it to the factory amp. Or will it be easier to just add a Lineout adapter and run an after market amp?
I haven't heard either way.
In previous models(LH platform - Intrepid, Concorde, 300M, etc) you would find the harness there and then when the cost cutting kicked in they started removing the wiring.
I am not sure if that is happening for the Charger yet, or if they started it from the get go. I think I read recently that the amp for the sub(not sure if it is the beats or HK or both) is behind the driver side kick panel, so the wiring for the amp would be up there and the speaker outs would run down the body harness. If I read correctly that is.
The beats sub sat in the right rear of the trunk whereas the Harmon Kardon sub(for Charger) was in the rear deck. That alone would mean there are probably two different harnesses for the car
