Suspension problems
Discussion in 'Dodge Charger Chassis - Suspension' started by treiterer, Apr 27, 2016.
  1. treiterer
    treiterer New Member
    Apr 26, 2016
    3
    0
    Wisconsin
    Vehicle:
    Charger
    Vehicle Year:
    6th Gen - 2006
    Trim?:
    R/T
    Color?:
    Brilliant Black
    I got an issue with my 2006 R/T. There is a clunking coming from the front end when I go over any kind bump. The car is lowered and the anti sway bar end were just replaced. I had my mechanic go over the control arms and tie rod ends and they were said to be fine. Could it be time for new struts? If so do I need to get a special length strut for my lowered vehicle? Also what kind of strut do you recommend, I like the best when ever possible.
    Thanks
  2. SMOKESHOWIN
    SMOKESHOWIN New Member Site Supporter Level 1 Public Safety
    Aug 26, 2016
    47
    5
    Hamburg
    Vehicle:
    Charger
    Vehicle Year:
    6th Gen - 2006
    Trim?:
    R/T
    I've got an 06 rt as well, w/ a noisy front end. Considering purchasing a 14 piece front end suspension rebuild kit for $184.99 from partsw.com. The price seems right, however the parts origin is suspect. I'm in the process of getting a labor install price.
    Seems like the kit parts are many of the same ones I've seen/read about that fail. Also, sway bar bushings are cheap ($10. or so), and an easy install. Good luck!
  3. gapi
    gapi Member
    Jan 26, 2016
    271
    28
    N. GA
    Vehicle:
    2013 R/T
    Vehicle Year:
    7th Gen - 2013
    Trim?:
    R/T
    Color?:
    Granite Crystal
    Sway bar bushings. Cheap. Sounds like a Q-Ball bouncing in your glove box?
  4. HemiLonestar
    HemiLonestar Member Military
    Feb 15, 2014
    440
    Media:
    7
    Albums:
    2
    54
    Gender:
    Male
    MD
    Vehicle:
    Charger
    Vehicle Year:
    6th Gen - 2006
    Trim?:
    R/T
    Color?:
    Inferno Red
    When I had this problem, it turned out to be the upper control arm ball joints, though everything was pretty much shot by 120,000 miles.
Share This Page
