hello from Nova Scotia everyone ,i'm trying to find out if 18"factory wheels from a 2013 Dodge Challenger will work on my 2012 Charger that has 18 "? Any help would be great ,thank you in advance
I'm sure someone will move this over to the suspension/wheels or another subforum, but to answer your question, OEM wheels 18"+ from RWD Chargers should swap from any model year Charger to another. '06 to '15 should all accept stock 18"-20" wheels without issue. Exceptions: AWD to RWD and vice versa - Wheel offset is different... RWD wheels have a lower positive offset, meaning that if they are put on an AWD car, they will stick out from the fenders. Opposite goes for AWD rims on RWD car - will be tucked further in toward the body, may not clear the suspension. 17" wheels - Available on some early model year Chargers, may not fit around brakes on SXT, R/T, SRT, etc, or 2011+ model year cars.
So, 18" - 20" stock wheels should fit on any model year Charger with zero issues, assuming they are AWD rims for an AWD car or RWD rims for a RWD car.
SRT wheel offsets may vary SLIGHTLY compared to SE, SXT, R/T models, but not enough to make much of a difference.
My '08 SXT AWD had 18" stock wheels... or at least that's what came on it when I bought it. The 2011-14 AWDs came stock with 19s. Not sure about the 2015s.
All OEM SRT wheels up until the 2015MY were 20x9" with a 25.5mm offset. These will require a 3mm spacer (front only) when fitting to a RWD R/T, SXT, or SE.
thank you for the info and the welcome ! Also sorry for posting in here as i'm new .I will watch the video on how to navigate the site.Thanks again everyone!
People telling you that are absolutely incorrect. :4-looney:
Both Challenger and Charger wheels are 5x115. As dperk pointed out to you earlier, Charger and Challenger wheels are essentially interchangeable except between AWD and RWD.
Underneath they are all basically the same car. Barring brake caliper size, al LX/LD/LC wheels are forwards and backwards compatible. 2012 and 2014 are within the same generation anyway.
sneaking in this thread to ask if my original Charger SRT8 6.4l from 2012 will fit a Charter SRT 392 from 2016, heard could be tight due to bigger brembos?! Thanks!
Thanks Lonestar! Well the thing iss as I upgraded and got 8 rims of the 2012 I tought instead of buying new winter rims it would be the easiest to use my winter rims on the 2016 Would you recommend or buy new ones?
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Dodge Charger Forum
1.8M posts
46.3K members
Since 2006
A forum community dedicated to all Dodge Charger owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, Hemi Mopar power, power-adders, and more!
