Does the 2009 sxt charger have a stabilizer bar in the front end , and if so do you replace both at the same time
Yes, if its the originals you most likely want to change both links and sway bar bushings. Are you getting a knock when navigating bumps?
No my tire on the front passenger becomes flat after sitting still for a day or so. I’ll definitely order both links and bar bushings any you recommend?
