1 - 13 of 13 Posts
So I'm wanting to change the 200degree thermostat in my Daytona 392 to the 180. Will this void my warranty? What's the reason dodge went with such a high degree thermostat?
2017 Charger R/T Blacktop
It will void any warranty claim that could be related to the thermostat change. The reason for the higher temp is for emissions.
Not for anything, but unless you're going to a 180º for a specific reason, that's a big drop. 180s have been known to throw codes.
Maybe consider splitting the difference with a 190º. I use the Stant 48799 (190º) in my 5.7s. No issues, no codes.
OE is 203 degrees for a reason.. efficiency ..If you just can’t help not changing it out try a 192 instead of the 180. if you live in a climate that gets cold the 180 could set a CEL for not warming up fast enough. unless you change the fan temp settings thru the tune the lower temp thermostat won’t help you much anyway.
Discussion Starter · #8 ·
What is the fan temp setting about?
If you do change to a lower temp t-stat you need to change the settings for the cooling fan(s) as well or they will run too long and too often.
Its usually done for tuning reasons, both of my FI vehicles have 180 t-stats at the requirements of the tuners.
Here is a shot of my fan settings showing highlighted in green the amounts the settings were dropped.
120640
Reactions: RustyColt
Yes, leave it as is. Back in the day.......the lower thermo would lower engine tempos, hence more power. With computers though, I will NOT second guess them.
1 - 13 of 13 Posts
