I’m so annoyed with the internet right now I’m looking for the torque specs for the 14 charger SE trim caliper bracket bolts and the guid pin bolts and also the sway bar link bolts and the sway bar bushing I can’t get a straight answer this is what I have but I want the exact factory specs are these right ?
Stabilizer Bar Link Upper (Shock) Nut = 74 ft. lbs.
Stabilizer Bar Link Lower Nut = 96 ft. lbs.
Disc Brake Caliper Adapter Mounting Bolts - Front/Rear = 70 Ft. Lbs.
Disc Brake Caliper Guide Pin Bolts - Front/Rear = 44 Ft. Lbs.
I can't say for sure about 2014 MY because the specs I have are for 2013 MY. I assume they're the same since not much changed between 2013 & 2014. Your stabilizer bar specs are correct.
The disc brake specs for 2013 are different than the specs you listed.
The front disc brake caliper adapter mounting bolts for 2013 are confusing in the Service Guide; there's two entries in the spec table:
Disc Brake Caliper Adapter Mounting Bolts - Front - Built Before On Or After 8/30/12 = 140 ft. lbs.
Disc Brake Caliper Adapter Mounting Bolts - Front - Built After 8/30/12 = 121 ft. lbs.
Disc Brake Caliper Guide Pin Bolts - Front = 44 ft. lbs.
Disc Brake Caliper Guide Pin Bolts - Rear = 23 ft. lbs.
