I have a 2011 Dodge Charger R/T that I bought last week with 12600 miles on it. This weekend we decided to take it to the mountains and when going up hill, something happens with the transmission. When going up steep hills, all of a sudden there is a bad grinding sound when letting off the gas. When applying the gas, everything seems to be fine. And when driving on normal ground, the problem doesnt seem to happen. Only when going up a steep hill and when the car works hard to drive upward and then I slow down, it makes the noise and the grinding sound and it feels rough. The first time it happened, I was going about 60 mph. The second time it happened I was going about the same. The last time it happened, I was only going about 30 mph, but I was going up a very steep hill, causing the engine to rev high and work hard. I took it to a shop, but they said just by looking at it that they cant tell what the issue is. Any suggestions to what is wrong?
Thank you in advance.
