1 - 8 of 8 Posts
I have a 2019 R/T. I’ve been having a weird shifting problem lately. Upon accelerating from a dead stop, the shift from first to second is not very smooth, you can feel it pause in between gears, almost feels like it slips momentarily before kicking into second.
It is way more common in the mornings when the car is cold, but also do it randomly even after driving for a while and fully warm.
I’ve spent hours searching and found a few people with this problem, but no one has come up a conclusion on what’s causing it.
I disabled hill start and also disconnected battery for 20 minutes and still happening.
Car has 3,000 miles. Bought it new
Any thoughts? Thank you
I guess I would check the fluid level as they are supposed to be critically sensitive to it. Get that out of the equation anyways.
The car only having 3k miles maybe the adaptive logic needs more time.
I have a 2016 A8 and a 2018 A8 and both have the cold first shift of the day manners you describe .after the first shift they are normal.
Don't know if this is an answer but something you can do "if possible because you'll be driving " write down trans temp, coolant temp when it does it and keep a log. Might show something might show nothing be good to have a log of info
How would I check that? These don’t have dipsticks right?
I’ll try, but it’s been doing it since day one when the weather was cool, and now when the weather has been 105+ daily. When it sports mode, it’s even worse. Every time I come down to 1st gear when slowing down on sports mode, it feels like I get tapped in the back by a car
you can get a dipstick anywhere [Rock Auto]...transtemp is critical....you can read it on gauges.....find a chart online that tells fluid level at proper temp.
1 - 8 of 8 Posts
