Checked all fuses. Trunk light not light up. I dis connect the latch lock connector and there is power at the trunk light connector (w/o bulb) measured. This also has caused intermittence with the Key Fob. Has anyone seen this issue.
I have not had this problem but I assume you tried a new bulb?
No.but used meter and it is not open. In fact it is do clear the filament is a solid line .which does mot appear to be boken.
