3-4 months ago, my trunk light went out. It kind of "fizzled out" rather then just going out right away. Tried replacing the bulb and checked all fuses and nothing. Let it be figuring I would mention it next time I took it in for an oil change. Then a month or two ago my trunk latch decided to stop working. Nothing from either FOB or the button under the dash. Took it in and they said that some wires were broken where the harness enters the deck lid. Has anyone else experianced or heard of this happening before? I have a 2009 R/T.
Yes, that's it. There are three wires that sit inside of the rubber boot that connect to the trunk's lid. One of them has probably snapped loose from the trunk being opened and closed as the boot sometime gets caught in-between where the it closes. You would just have to take a wire cutter and reattach with electrical tape. After this you should be ALL set with the FOB and the inside trunk release button. Oh also the third break light
