I have a 2014 charger rt awd but it doesnt have the backup camera package and was wondering if their is a way to install one where it will show up on the 8.4 uconnect screen
It would depend if your car is pre-wired to support a backup camera. If it is, there should be some kits on eBay for around $200 the last time i checked. From that point, you would probably need a TaZer to enable the backup camera.
You need a taser and a cheap back up camera to do so should cost you 300 in total but its super easy and there is multiple uses of the taser then just unlocking the back up cam
If your car already has the wiring harness you might be able to find a 3rd break light with the camera on eBay. From there it's just activating it in the radio if it's not already.
take down the edge of the trunk liner around the latch and see if there is a grey unused connector hanging there next to the brake light module if so, you're in luck, the car is prewired for a backup cam...you can get an OEM module with cam from Mopar [$$$ 250.00] and have a dealer activate it or use a Tazer and do it yourself...
