Keep getting check engine light on, code is for coolant, doesn’t run hot. In the past I have added coolant to reservoir, was maybe 1/2 inch low and after a few days check engine light goes off and stays off for a few months. I don’t see any leaks, anyone got any ideas? Is there a sensor for coolant level? Any other sensors cause this?
2017 Charger R/T Blacktop
Had that on our 2011 Charger, it was the thermostat.
I’m not familiar with thermostat replacement, do I need to purchase just the thermostat replacement or the housing with the thermostat already installed in it? , I see them for purchase online both ways,It’s a 3.6 liter .
Look in my signature. You will see a link to Chilton free access guide. It will give you all the information you need to replace the thermostat
