Water pump gasket sealant
8K views 6 replies 3 participants last post by  ChargerJohn
That sure looks like a rubber gasket to me. You don't put RTV on those, you don't need anything,just bolt it on.That also goes for rubber gaskets for trans pans, oil pans, etc. The guys at the auto parts store should have told you this.
I would take it back off and clean the RTV off the gasket or else it may leak.
You must have really cranked down on the bolt to snap it off, check the torque spec but I think it's only around 20 ft/lbs.
I used alot of RTV on my 70's/80's cars, but I can't remember the last time I bought a part for one of my newer cars and it had a cork gasket, pretty much everything nowadays comes with a rubber o-ring/gasket. I had some RTV sealant but it dried up because I hadn't used it in so long.
