Water pumps commonly going out low mileage?
1 reading
3.4K views 9 replies 9 participants last post by  gapi
I noticed a lot of people having water pump issues at externally low Mileage.. I have the road and track pack. I have beat this thing all across the country. I’m at 156k and it’s still going strong. I want to replace it before it does go out, but I’m worried about “getting a bad one”. Does anyone have any insight on if the problems been fixed or not?
#7 ·
Does the same apply to the radiator? I had my original replaced two years ago when it developed a major leak. They did not use a Mopar replacement. The dealer got the radiator from O'Reilly's Auto Parts. The water pump was not replaced at that time. Just recently it failed again, but not as bad of a leak. I went to a different dealer this time. Both the radiator and the water pump were replaced with Mopar parts.
RamAirV1
#5 ·
I was one of those that had my water pump go out early (27,000 miles). I replaced it with a remanufactured pump before finding out those were crap. Ended up getting a OEM water pump with 33,000 miles or so and it has not failed in 8-9 years.
Like said, if it isn't broke don't change it and chances are it will last a lot longer than you think. You have one of the good ones.
#8 ·
I had mine replaced at 54k miles and wondered why so early at normal daily driving. Had it replaced and now I have double the mileage and replacement still going strong. Could be just production or assembly problems being it was the new model design from the 2014 model.
#10 ·
My 2013 WP failed @ 113k miles. Almost 200k miles now on the replacement MOPAR pump.
Reactions: MadMaxx
