hey all. My first post and I need some help. I just got a new TCM due to some horrible shifting problem and I want to see if this will resolve the issue before I dreadfully have to take it in.
I have watched several videos as to how to switch it and when I took the dash panels in the drivers side under the steering wheel off...I could not locate it.
Is there anyone who can help out with this?!
Btw...it’s a 17 SXT
Moderator
I don't know if the location has changed between 2011 and 2017, but what you describe is exactly where mine is.
I assume your 2017 has the 8-speed transmission ((8HP45)? The TCM for the 8-speed is inside the transmission. The valve body includes the TCM, all solenoids and sensors, and is referred to as the Transmission Control Module Assembly (TCMA).
The TCM for the 5-speed (NAG1, W5A580) is under the dash.
You should try software updates before swapping the TCM. New TCM is a last resort and most likely not the problem.
Discussion Starter · #6 ·
Thanks. I did once but not from the dealer. I will call the dealer and see what they say.
I appreciate everyone here for the input.
